Performance Lab for replicaset
Bertrand Gineste shared this question 2 years ago
Need Answer
Hi,
I use DB_Koda mainly for ReplicaSet. In the performance Lab, is there a way to get OS stats for all the nodes of the cluster ?
Is there a way to refresh the tree view ? if I stepDown my replicaSet, the tree view doesn't show the changes, and I can't find a way to make this .
Thanks for the good job.
BeGin
Comments (1)
Hi BeGin,
Thanks for trying dbKoda!
We currently don't show replica set statistics directly in the performance lab, but you can run multiple performance lab windows. So you could open one window for each member of the replica set. I know that's clumsy, but until we add a replica set view that's the best we can do.
To refresh the tree hit the refresh icon at the upper right of the tree pane - just to the right of the search bar:
/mOXSAdtWXtOpA7KIIAAAggggAACCCCAQPIEevy9vJuu9KZstLz+NP+9Nm3T7DneNH9+e69n97Wtz53mz2Pvo+VxP9Pfg9z37utovyP9f4StNI5ixmibAAAAAElFTkSuQmCC
Thanks again for trying dbKoda and let us know if you have any other requests!
Regards,
Guy
Thanks for the reply.
I'll take the workaround, it's not perfect, but I can live with it ...
About the refresh button ... It was hidden by right part of the screen :)
/KkB14YZnx3WPcYK3PkUbQfaXBEiABKKMgPSaDm995vysNzKMJwESIIHoIeB1Tonzs9HzJWBPSYAESMAbgf8fKw6rARwmxb0AAAAASUVORK5CYII=
Thanks for the tip ...
A new request :
/w9U5swGpJzWQgAAAABJRU5ErkJggg==
In the Collection statistics, could you please display units ? Here my object size is 612 B but the size and storagesize should be in KiB or Mib
Regards,
BeGin
